Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1700 Perguntas Visualizar todos
Ps4 Infested with cockroaches I need help!
My ps4 is infected with cockroaches like I said in the title but what I need to know is if there's a repair shop that will fix cockroach damage and if there is please tell my the the name of the store. It would be convenient if it was in LA will check daily.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Thank's but I really don't want to mess up the ps4 but still thanks
por
Adicionar um comentário
4 respostas
Solução escolhida
Here's how to tear it down: PlayStation 4 CUH-1200 Entire Console Disassembly
Here's some info about your roach hotel:
http://kotaku.com/5979683/remember-your-...
I know of no technicians that would touch it. I even have a warning on my Thumbtack page that says if it is so dirtyI don't want to touch it to find someone else. A tech will probably charge you more to clean it than it's worth. This is a DYI repair!
Esta resposta foi útil?
Pontuação 5
My business fixes cockroach infested PS4's all the time. You can click on my name and it will take you to my profile that will have links for my website and FB page.
Pontuação 2
5 comentários:
Why do these get infested?
por
The cockroaches love the power supply because it's dark and warm. It's the perfect place for them. https://www.youtube.com/watch?v=3fExaccW...
por
So is it usually as easy as changing the power supply??
por
dang your website is really expensive!!!!!
por
and also when u are changing the power supply do u have to clean the ps4?
por
Carlos carreno what i did took 3 hours but worked perfectly clean the system using a air compressor or a air can after that purchase fly screen cut the fly screen into segments that will fit perfecty over the ps4 vents apply small amounts of super glue not in the vents but just next to them this whole proccess can take upto 3-4 hours depending on how steady your hands are after this purchase a small usb powerd desk fan to ensure your console wont over heat if you complete this nothing can infiltrate your system keep in mind though you will have to clean your vents ever 3-5 months i hope this helps you
Pontuação 1
I killed all the cockroaches in my ps4 slim by putting the ps4 in a white garbage bag and cut all the oxygen off made sure it was tight clean and another garbage bag that was black and i prefer the mint smell kind I did the same thing and made sure it was tight no oxygen then I put it inside a hot car on a hot day let it set for a 2 hours went back opened the garbage bag and a lot of dead cockroaches it was nasty to clean up but it did the job without spending a lot of money. Sincerely BENSOR
Pontuação 0
Adicionar a sua resposta
Carlos carreno será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 27
Duração total: 21,789
