Ir para o conteúdo principal
The Blu Dash JR D140 cell phone was manufactured by the Blu company in 2013, their headquarters is Doral, Florida.
says radio off when I try to make a call
Trying to activate the phone. The screen says removed sim card. The card is in but when you try to make a call the screen says "radio off" call not sent dial emergency #. Called Tag mobile, they said to try the sim card in another phone. We don't have another phone that takes the mini sim card. anyone with any ideas? This is a disabled client of mine, limited income, so has this phone and he needs it to work. Thanks to anyone who has an idea we could try.
Esta é uma boa pergunta?
Pontuação 3
8 comentários
The sim tray may be damaged. Go to settings>about>status and see what you get for the cellular related info.
por
My phone network is not coming what to do
por
Can't make a call because radio off. What do I do please.
por
I .may phone I see sine Radio off
What this min and haw this affect may phone
por
Do you have a hey Google radio, turn it on then call all the numbers affected by radio off then when you've proved that they are now connected turn off First your mobile Then your hey Google, I don't know if it is the same with Alexa but this was my problem and I figured it out as I remembered I'd turned my hey Google radio off at the plug in the middle of the phone call, hope this helps
por
Exibir mais 3 comentários
Adicionar um comentário
2 respostas
Solução escolhida
the problem is probably that they already took down 2g towers this phone runs 2g so it would no longer work
Esta resposta foi útil?
Pontuação 2
2 comentários:
I have a BLU2. When this happens (Radio Off), I do a total reboot and on new start-up, problem solved. You can also try removing and resetting the battery.
por
@Linda Liggett wriglesworth Since the problem is 2G towers, you will have to get a new phone. Would you prefer a smart phone or flip phone? What carrier do you use?
Pontuação 1
3 comentários:
My phone model is vivoY71
por
Please give me solution. I can not Call any one because it show radio off
por
@Most munni Khanom Get a 4G capable phone and get a new SIM card from your carrier.
por
Adicionar a sua resposta
pris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 35
Ao todo: 17,207
