Ir para o conteúdo principal
Wi-Fi signal is weak and there is no GPS
After replacing housing on iPhone 6 appeared next problem: Wi-Fi signal is weak and there is no GPS !!!
& yet, apparently bent battery and is now at 30% off the phone )
but are interested in the first problem !!!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Check if every screw holes and contact clips at the top are installed as the original.
Esta resposta foi útil?
Pontuação 1
2 comentários:
and exactly which check ?
por
The ones near the top left and middle. The screw holes must be conductive from board to frame.
Also check the L shaped RF cable on the upper back of the board,
por
Adicionar a sua resposta
Yury será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 134
