Ir para o conteúdo principal
The sixth-generation Volkswagen Jetta, known as the NCS (New Compact Sedan) during its development, was announced in the North American market in June 16, 2010.
2014 VW Jetta S Oil Change Bolt question
The bolt is on very tight, which way do I turn so so I don't strip the bolt?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
@garrett28 you will always find bolts tighten by turning them clockwise and loosen by turning them counter clockwise . the only exception will be when the bolts are spun ( moving ) and require reverse threads to keep them from spinning off. Like kaniggit49 said "Righty tighty, lefty loosey."
por
Adicionar um comentário
1 resposta
Solução escolhida
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
James Garrett será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 952
