Ir para o conteúdo principal
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 Perguntas Visualizar todos
Ipad Display dim on one side after Glass Replacement
I just completed a repair of my mom's iPad 4 - The display was cracked so I replaced the digitizer and plastic ring around the outside. Part of the black dust strip was ripped so I peeled some of of it off on the lcd screen itself. Once assembled the display is dimmer down almost half the screen exactly. Is this because the black fabric / foam dust strip is removed or what else might it be?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hey @jeremy, you'll probably have to replace the LCD connector or the board of the iPad. One of the backlight filters probably became shorted out after the replacement. Here's one tutorial you can follow for fixing the issue.
-Let me know how it goes
Esta resposta foi útil?
Pontuação 1
5 comentários:
Thanks for the feedback - I'll look into this.
por
Cool keep me updated.
por
Fixed - I disassembled the ipad again - disconnected the LCD cables - cleaned them and reseated them. That restored the backlight. Thanks for pointing me in the right direction. Glad it wasn't more serious as noted in the video.
por
Awesome! I'm glad I could help :)
por
You would be surprised how dust inside the display connector can cause this sort of problem. I had to clean up the connector with a fine brush to get the dust out.
por
Adicionar a sua resposta
jeremy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 4,553
