My phone signal is not indicate when I insert slim card
My doogee valencia2y100 phone signal is not indicating please help for solution
Esta pergunta é pertinente?
Take out the simcard and clean it with microfiber if you have that (don't try enything else).
If that doesn't work,try calling someone and/or go to call settings and change Preferred Network between Global, LTE , GSM, CDMA, UMTS(depends where you're from) . Try it in a different phone if you can.
If neither of these worked the problem is most likely the sim card.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 182
