Ir para o conteúdo principal
Repair guides and support for motherboards and CPUs.
Why is my cpu not responding with my monitor?
how can i fix my cpu, its just opening but the monitor is says " no input, go to power save" and then it turn off but the cpu is still open???
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
what do you mean when you say : cpu is opening? CPU is still opening? Do you mean GPU?
in that case :
The posbilites are:-
Loose cable, or bent pins on cable.
Loose video card.
burnt out power for the video card chip on mainboard (smells bad).
Video card is dead.
check all the connection and check with on board graphics or another video card?
Kind reagrds,
kevin
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
rochelle será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 187
