Ir para o conteúdo principal
Power light continous green LED flashing for +/- 5 seconds, tv "dead"
Power LED when switching ON, flashes continuously GREEN for about 5 seconds and then steady GREEN LED - and no display on the screen - blank /"dead".
Under normal conditions, the GREEN LED will flash for about 3 seconds then "flip-flop" to RED status, i.e: TV is now in "standby" mode.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Locate the DG Board (Audio) and re-solder the DG Board connector pins of both power supply connector from the main Power Supply Board.
A "dry joint" was not allowing theDG board to fully 'diagnose and reset' on Power On...
( In my case the DG board was the TNPA4311 )
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
jotburke será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 120
