Ir para o conteúdo principal
A versão econômica do Samsung Galaxy S4, lançada em julho de 2013.
Why can I get no network access
Hi, having just repaired an s4 mini, which is locked to EE, I've put my normal EE sim card in the phone, but get no network access at all. When the sim is in my other Samsung, there is a good signal. Does anyone have any ideas what the problem could be? I can save contacts to the sim card, so I think the sim reader is ok. Could it be an antenna? or is there another part that could be at fault.
Many thanks
Esta é uma boa pergunta?
Pontuação 1
6 comentários
Are you on the stock software?
por
Hi Ethan, yes. Standard software.
por
By no network access, do you mean that you don't get a signal, or it gives you an error when trying to call someone
por
Actually both. Circle with a line through it at the top of the screen. If I try to make a call I get a message saying there is no network connection.
por
Hmm do you have all the required antennas properly inserted?
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Solução escolhida
Hey Bigphilly71,
I would recommend you contacting your provider, maybe they can help you! Also, check your motherboard if everything looks alright.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bigphilly71 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 795
