Ir para o conteúdo principal
Broken Rear Camera Bracket
Im looking to order a part, but i cannot find it anywhere. Broke the bracket underneath the rear facing camera while trying to do a lens replacement. Does anyone have a part number or link for this ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Is this what you need?
Esta resposta foi útil?
Pontuação 3
2 comentários:
I do believe that will do the trick, thank you! never thought to check e-bay
por
Ebay is my go-to, to be honest, especially for the little parts that a normal supplier would not have. Otherwise I would be posting what we have on here.
por
looking for this as well but in the uk, all i can seem to find is the bracket without the plastic on it
Pontuação 0
Hi, my boyfriend has same issue and the camera has problem afterward. Did you success to fix it??
Pontuação 0
Adicionar a sua resposta
jeffwadford será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 232
