Ir para o conteúdo principal
Repair and disassembly guides for Magellan GPS devices.
67 Perguntas Visualizar todos
Why would my GPS switch not turn on the device
My device not turning on despite charged
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
My GPS will turn on when plugged into car socket. I cannot turn it on manually because the turn on button is not working. I want to update my GPS from my laptop . Got the connection I need, but, can't turn it on manually to be able to do this. Is it possible to get it fixed somewhere. My postal code in Canada is L7T 3Y4
por
Adicionar um comentário
2 respostas
I have this problem with my 9400-LM if I have a backup camera connected. If the video cable is unplugged from the 9400, the unit will respond to the power button. The camera is supposed to be compatible with the 9400, but apparently it is not.
Esta resposta foi útil?
Pontuação 0
my magellan 9020t is not turning on weel is spinning that's all inst. new batterie no result
Pontuação 0
Adicionar a sua resposta
Tunde Aina será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 364
