Ir para o conteúdo principal
Machine-readable instructions that direct computer processors.
SQL server after RAID problems
We had a SQL server die due to some RAID problems. We sent the machine out to a data recovery company and they are able to recover the .MDF and .LDF files from the drives. Will I be able to use those files to restore the databases to a new machine?
What do I need to watch out for? Thanks!
Esta é uma boa pergunta?
Pontuação 1
1 comentário
You've been very kind in your efforts to help. Thanks for that. Solved!
por
Adicionar um comentário
1 resposta
Solução escolhida
Have u tried out the old way of creating empty database with same name.
Stop sql server
Paste database at the same location ...
And restart the server ....
Does it helping u out .....
If that doesn't help, then the only thing I can advise is to try to restore database using SQL Server Recovery Toolbox. All the details about this program can be found at the link. http://www.oemailrecovery.com/sql_repair...
Esta resposta foi útil?
Pontuação 1
1 comentário:
May be this article will give you more information.
http://www.techrepublic.com/forums/quest...
por
Adicionar a sua resposta
DanielNetrval será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 699
