USB port not working on HP G60 portable
HP G 60 not recognise the USB ports
Esta é uma boa pergunta?
all the usb ports not working the pc is loaded win7 64bit
Esta resposta foi útil?
Is your USB port working with normal USB drive (not the one you are using... bcos ur USB might not work at all)?
If not try updating your USB drivers, that will fix the issue.
it does not detect printers flash etc
Yes its all because of drivers ... once you have complete drivers it will start working normal
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 183
Is the unit connected to a Windows 10 PC because Windows 10 currently has an issue with printers connected via usb cords in that windows 10 has an error that microsoft has not fixed. So try using wireless printing or connect it to a computer with windows 8 or 7 or linux.
por Brian Reeder
