Coffee grounds in cup while brewing
Grounds coming out of K cup while brewing
Esta é uma boa pergunta?
I periodically insert a safety pin into the top needle....then I choose and run the "hot water" function....you should notice grounds in your cup. Repeat the safety pin procedure until the water is void of grounds. Others may use a straightened paper clip. Be careful.
BTW: I often do this during the brewing process....the brewing stops when you lift the lid.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 104
