Ir para o conteúdo principal
The Motorola Xoom is an Android-based tablet computer by Motorola, introduced at CES 2011 on January 5, 2011. It is the first tablet to run Android 3.0 Honeycomb.
Remove SD card from SIM slot on Motorola Xoom
By mistake inserted a SD card in the SIM slot.
Saw the repair steps and it looks like this area is open just after the "slide of the Panel".
Can I access the SIM area to remove the SD card at this level?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Yes, Slide the panel off and you should be able to retrieve the card. This is common with these and I have retrieved sim cards and SD cards from a few.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Cy Clone será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 287
