Ir para o conteúdo principal
Originally released on January 22, 2005, the Mac mini is a small form-factor desktop computer made by Apple Inc. Currently, it is one of the four desktop models in the Macintosh lineup, and serves mainly as an alternative to the all-in-one iMac.
872 Perguntas Visualizar todos
Pergunta encerrada
FAN at max speed after hard-disk replacement
I followed instructions to replace the internal hard-disk, but I think I've damaged one thermal sensor, now fan is running at full speed and is not possible to slow down it via software (I tried with SMC Fan Control).
Is there any other way to force control of the fan ? I don't know where to find another thermal cable here in Italy...
Thanks
Esta é uma boa pergunta?
Pontuação 0
2 comentários
This is a Mid 2010 machine. It's under warranty. Why are you replacing the hard drive?
por
Ok I'll try to find a new sensor cable...
por
Adicionar um comentário
2 respostas
Solução escolhida
If you don't plug in the sensor in the first place, the fan will run 100% all the time. Make sure the other end is plugged in where it belongs?
If the sensor part really is broken, your options are kinda limited. You can mail order another one if you want, they seem to be running about $25 though I know nothing about shipping to Italy. Apple calls it a "hard drive sensor cable" and here's your google search.
I would imagine if you really like hacking your hardware you could get a manual fan control and just set the fan to the highest noise you want to put up with but that's really a horrible way to treat a brand new computer.
Good luck!
Esta resposta foi útil?
Pontuação 1
1 comentário:
I've changed it with a SSD unit
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 2,751
