Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
problems with iPhone 5c
My iphone 5c froze so I shut it off using the home and power button now when I try to turn the phone on all I get is the apple logo and several white vertical lines. Does anyone know if I can fix this somehow?
Thank you
Taylor
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
This could be caused by one of several things.
-You have have dropped the phone recently, or immediately before the issue, which caused damage to the LCD.
-You may have water damage in the phone causing this.
-The most likely cause of this issue though is that you've had the screen replaced before from a third party repair shop and it's a faulty screen. I would suggest that you go back to the same shop and see if they can do a warranty repair for you.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Taylor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 62
