Ir para o conteúdo principal
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Perguntas Visualizar todos
I think I need a new RAM port...
Hi All,
So a few months ago laptop started giving me RAM Issue beeps. So I replaced the RAM, which didn't seem to fix the problem. In fact it seems to have gotten worse. When the computer is running it easily reads all 16GB of RAM until I hold it. Then it freezes and starts giving me the RAM Issue beeps. I'm on my 3rd set of NEW ram and it's doing the same thing. Does anyone have any thoughts, or know where I can get a RAM port for a Early 2011 Macbook Pro 15"? I appreciate all your help.
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Please tell me what programs can address 16 MB of RAM because I'm not aware of them. This machine has possible videos issues, has it been tested for the recall?
por
@mayer Many can, you meant 16GB right?
Might be a good idea to clean the RAM slot and try the RAM again.
por
Already tried cleaning the slots, multiple times. (This is b1ackn1nja BTW)
por
Adicionar um comentário
1 resposta
Pergunta mais útil
This is a problem with the inherent design of these boards. One RAM slot is attached via through-hole soldering on the logic board, and rarely fails. The other is attached through BGA, and is very easy to break if the slot is bent or computer dropped or one of Jupiter's moons goes on the far side of the planet. It's something that needs care when working on the board, and it sounds like you may have one bad slot. I've yet to see both go bad at the same time.
Since you said you have 16 GB of RAM, you will have an 8 GB card in each slot. I would start out by removing both RAM cards and only inserting one in the top/closest slot. Run the computer with 8GB and see what happens. If you get no errors, it is likely the BGA soldering on the further RAM slot. If that doesn't fix it, try just one RAM card in the bottom/furthest slot. It may be the top slow somehow failed in a strange twist of fate, that is what we're here to find out.
An actual RAM slot replacement is not something easy or at all straightforward, and not without risks. Many people choose to just use one RAM slot if the have only one good slot. If none of this fixes it, it may need a new memory controller or parts of the memory circuitry replaced.
Anyways, try either RAM slot on its own, see what happens, and we can go from there.
Hope this helps.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
b1ackn1nja será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 103
