Ir para o conteúdo principal
Released March 2016, the Rift CV1 is the first consumer-targeted virtual reality headset by Oculus.
33 Perguntas Visualizar todos
Disassembly and repair of USB terminal end of headset cable
Replacement Cable
It may be virtually impossible to repair the USB if damaged.
I hope these pics help. If you have any thoughts, please share.
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
please photos your conector hdmi send my e mail. similar and usb is posible ,
por
Adicionar um comentário
4 respostas
Can you post the pics? I've heard problem with some cables, but many new cables have chipsets, so not sure if design of cable is flawed.
Esta resposta foi útil?
Pontuação 0
2 comentários:
You may be able to find a replacement from this company: http://www.china-hdmi.com/products_detai...
Looks like the Oculus Rift 2 in 1 cable. (HDMI and USB)
por
I don't think so, Jim. The circuit board in the Rift appears to be made for the VR and possibly upcoming upgrades. I could find no link between the manufacturers. Definitely, the Achilles heal is the cable at the computer end. Movement in VR and orientation in reality can pull at a 90 degree angle, severing the fragile connects.
por
Can you put pics please ? Regards
Pontuação 0
1 comentário:
Sorry so late, here you go, marianol3d. Hope this helps.
por
Where can i get that cable. Ggoryn@gmail.com
Pontuação 0
1 comentário:
From my in-depth research, currently only through Oculus.
por
please is posible photos your cable breack for conector hdmi ,help my is breack pin bundle no garanted
Pontuação 0
1 comentário:
for posibility repair thanks ..
por
Adicionar a sua resposta
Jack Abernathy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 3,470
