Ir para o conteúdo principal
The LG G Watch R is a Smartwatch manufactured by LG that includes many features of a Smartphone and a full-circle P-OLED display.
Watch only works on the charger
I have an lg g watch r and I loved it i don't want to get a new smart watch because this one looks the most similar to the watches I wear. My g watch worked all the time no problem one night I went to bed and when I woke up i saw it didn't charge so I tried to put it on again. That didn't work. Then I tried getting a new cradle that still didn't work. I've tried Factory reseting it and that hasn't helped either. The watch works completely normal and fine when it's on the cradle the moment I pull it off it shuts off. (It does the powe ring down screen not just turning straight to black) any suggestions on what to do next. I'm thinking I need to change the battery but it didn't even start to slowly get worse it just went from working normal to not working at all off the charger please help and if I do need to change the battery where would I find it because I've looked and I can't seem to find the battery.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
http://www.fonejoy.com/genuine-lg-w150-u...
Had the same problem and yes I bought a new cradle too. The link supplies a replacement battery with carriage for about £21. You need Torx 4 bit and follow the tear down. Getting the band off was the worst bit, go very carefully with taking the connectors off but otherwise Ok. Just done mine and is now charging up fine. On arrival the new battery had 30% charge. Recommend the Ifix tool kit for jobs like this!
PS don't worry whether it's an LG Watch R or an Urbane they both use the same battery.
Esta resposta foi útil?
Pontuação 0
I ,ve change the battery and now it work . I had the same problem, that I solved changing the battery package. I find the replacement into this website from NUTELL . 3 days for delivery, 5 minutes to change..
Sorry for my English, but I can’ t use translator.
Pontuação 0
Adicionar a sua resposta
Chris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 2,416
