Ir para o conteúdo principal
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Perguntas Visualizar todos
Mac beep after hd replacement
Hi guys, My mac stopped working, and when i performed the apple hardware test it said that i had an issue with the heat sensor of the HD, so i replaced it with a new one...
Now, when i try to start, the symbol of the bin with a "?" in it pops up. Thats normal, since i don't have the system installed on that new HD.. but when i try to start with the Instalation DVD, the mac starts to BEEP...
In the internet, some people said it could be a problem with bad RAM, but i'm curious by why this happens only when i try to run from the DVD..
Can anyone help me?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
How many beeps? Is the a discernable beep sequence? As to the fan sensor, did you change brands of drives?
por
Hey Mayer,
3 beeps, 5 seconds silence, 3 beeps (continues to so forever...)
I used the same brand of HD (SeaGate) that came with the Mac..
por
Adicionar um comentário
1 resposta
Solução escolhida
The three Beeps indicate a RAM issue. First try reseating the RAM. That failing, insert just one stick at a time to test both the RAM and the RAM slots. Either can fail.
You may also have hard drive temperature sensor errors when changing drives on this model. Again did you change brands? OWC makes an in-line sensor that solves the run away fan issue (if you have it).
Esta resposta foi útil?
Pontuação 1
2 comentários:
I did a reset in the RAM with Command (⌘), Option, P e R... stiil beeping.
Tried with one stick at a time... still beeping..
Same brand of HD..
por
Here's what Apple says about the three beeps, keep testing: https://support.apple.com/en-us/HT202768
Here's how to change it: iMac Intel 27" EMC 2429 RAM Replacement
Have you changed the RAM/ What does your system profiler say you have? Compare it to what you see.
por
Adicionar a sua resposta
Giuliano Caneppele será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 1,752
