Ir para o conteúdo principal
Smartphone Android de 6ª geração projetado pelo Google e fabricado pela LG. Modelo LG-H790. Lançado em outubro de 2015.
Replace/Transfer Nexus 5X Notification LED
I'm about to replace the screen and frame for my Nexus 5X due to water damage (all components seem to be working, just the LCD is messed up). I read through the tear down instructions here and it seems like a pretty straightforward repair. But, I do have one problem, the Notification LED. the LED can be seen in the picture on step 13 for the teardown here, and it seems to be removed in the final picture of the teardown here, but there's no steps on how to actually remove the LED or replace it.
The replacement parts that I received comes with a new frame with the LCD/digitizer already inserted, but does not seem to have a notification LED with it -- is it possible to remove the LED from my old frame and transfer it to the new one?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
It is possible, but pretty hard. I was able to remove it by using a safety pin and heat to loosen the adhesive.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Alex Townsend será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 21
Ao todo: 722
