Ir para o conteúdo principal
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Perguntas Visualizar todos
Help identifying the CORRECT Logic Board Part #
MacBook Pro 13" Retina Display Late 2013 -...
Howdy folks! A customer of mine has a MacBook Pro who's logic board that was damaged by water. A water bottle spilled in her laptop bag . The red water indicator under the trackpad ribbon connector is positive for water damage. I am looking to properly identify this board so I can order a new one. I thought the BEST thing to do is share a picture of her back cover so you smarties can see for yourselves what model and other machine specific identifiers.
I'd also like to ask if you know where to get parts from a REPUTABLE distributor.
THANKS in advance!
Glen
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Here is your part.
MacBook Pro 13" Retina (Mid 2014) 2.6 GHz Logic Board
Imagem de MacBook Pro 13" Retina (Mid 2014) 2.6 GHz Logic Board
Produto
$219.99
Esta resposta foi útil?
Pontuação 3
4 comentários:
I used http://www.everymac.com to ID the computer via serial number.
por
Apple Part #: 820-3476-A
@ilabbe - once you do identify a machine, it's best to correct the icon so they can get to the guides
Here's the replacement guide: MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement
por
Correct the icon? I'm not sure what your mean. But THANK YOU GUYS for your help!!!
por
Ahhhhhhhhhhh!!!!!!! <Screaming like a frightened 5 year old girl> $700 dollars??????? My customer will fall over backwards, BUT... now that I know the part number I suppose I can look elsewhere.
Thanks again!
Glen
por
You might want to finish your profile so you can establish yourself as a professional with iFixit to get better pricing. Click on either my icon or Johnathans to look at those profiles.
Pontuação 3
2 comentários:
Thank you Mayer!
por
Yes, that price is way out of line and not at all in line with current prices on the marketplace. I would contact customer support and ask for a price update after you are set up as a reseller. But as you may know, other part sellers sometimes put an artificially low price on a part and then when you go to buy it find it is out of stock. Here's an example : http://www.powerbookmedic.com/MacBook-Pr...
por
Adicionar a sua resposta
Glen Comstock será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,479
