Ir para o conteúdo principal
The Sony CyberShot DSC-TX9 was a “point and shoot” portable camera released in October 2010. It features a built in speaker, a 4X optical zoom with 12.2 megapixel resolution, and a 3.5 inch LCD touch screen.
4 Perguntas Visualizar todos
Sony DSC-TX9 Error E:61:10?
Error E61:10 blinking on camera. Unable to focus. Zoom doesn't work either. Ideas?
Esta é uma boa pergunta?
Pontuação 8
1 comentário
Thanks. But unfortunately the autofocus seems to be completely screwed up. Tried absolutely everything, including your suggestion, but to no avail.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Error code E:61:00 mens your camera lens sensor problem
Turn the camera off
· Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
OR reference the video files below for an alternate method.
· Turn the camera on
· Let the lens extend into the hard surface, don’t let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
· Lift the camera away from the hard surface and notice that the error message is gone.
· Take pictures of your favorite things.
NEW
Here is a video of the normal power up sequence of the camera.
Here is the first alternate method
Here is the second alternate method
Another fix is on youtube.
https://www.youtube.com/watch?v=eXB3Zyeh...
Esta resposta foi útil?
Pontuação 6
1 comentário:
Geweldig! Het werkt super .
Dacht inderdaad dat ik mijn videocamara kon weggooien. Maar met iets simpels ( als je het weet
por
Adicionar a sua resposta
Andrew Bishop será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 80
Duração total: 9,591
