Ir para o conteúdo principal
Repair information for Roccat Kone gaming mice.
Is it the fuse that burned?
The connecting wire of the mouse to my laptop, touched a little water. (me stupid connected it straight to my laptop) Did the wire burn? or does it have a fuse in the mouse?
It would be great if you could help by answering.
Thank you for you're time!
Dominic Michaelides
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Theres no fuse or safety chips in side the mouse and since the use dongle is wet 1- you may damaged the laptops motherboard because of shortcircuit connection( dry the port and try sth else like flash drive to see if the usb is working...or not )
2 the mouse it self might be dead because of shortcircuit btw positive /negative and data wires.
So if after drying everything and getting one of these not working ,dont panic :/ its dead and theres nothing to do about it( buy a new mouse or fix some components on laptop - if usb not working)
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
dominickyriakos será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 465
