Ir para o conteúdo principal
O Samsung Galaxy S4 Active é uma versão reforçada do Galaxy S4. Atualmente, ele está disponível apenas na rede 4G LTE da AT&T.
Can I use a different model to replace the LCD?
Okay, I have the Verizon version of S4 SCH-I545. The LCD needs to be replaced. I also have available a working LCD from the ATT I337 S4 which includes the frame. I read that they have different frames and home flex so you can't just use any version to replace LCD.Can I just switch the LCD to the Verizon model motherboard?.Do all the motherboards match up? Can I just transfer all the parts to the I337 LCD frame? Or is the home flex connection different on the verizon motherboard?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
It says that the S4 active is AT&T only... Is it unlocked?
por
Adicionar um comentário
2 respostas
Solução escolhida
No. The Samsung Galaxy S4 screen is completely different from the Samsung Galaxy S4 active screen. Neither will work on the other.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Are all the ATT S4's using an active screen? I don't know if mine is active.Anyway to check?
por
yeah i have a galaxy a50 and the model is a505U and i used a a505f, it was working fine at first then vertical lines started appearing. it’s most likely because the different models.
Pontuação 1
Adicionar a sua resposta
xsilicon9 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 1,825
