Ir para o conteúdo principal
The second generation Moto X (marketed as moto X) is an Android smartphone developed by Motorola Mobility. Released on September 5, 2014, it is the successor to the original Moto X released in 2013. Model numbers XT1097, XT1096, XT1095, and XT 1093.
45 Perguntas Visualizar todos
Why does my phone keep on restarting then shutting down again? Help!
For the past two days, my phone has been restarting itself to the Motorola logo, then turning itself off, over and over again. I've tried to externally factory reset it and clear the cache partition. Nothing has worked and it always goes back to the Motorola logo only to restart again. Does anybody have any ideas to fix this?
Note: The night before I put my phone to charge at 3%, but it was charging for the entire night. The next day it was in the condition it is now. Don't know if that helps.
Please help!
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
The micro-USB port needs to be replaced.
por
Adicionar um comentário
3 respostas
Download the stock firmware and flash it via fastboot.
Get into fastboot mode by holding power+volDown until you see the fastboot screen.
Here is a more detailed rundown of how to flash the images.
https://motorola-global-portal.custhelp....
Esta resposta foi útil?
Pontuação 0
I would check your charger. What you describe sounds like an extremely flat battery. Plug in a different charger that you know works and see what happens. Otherwise you may have a problem with the charging board or circuit
Pontuação 0
Probably, the micro-USB port needs to be replaced. UbreakitIfixit, a national chain could fix it.
Pontuação 0
Adicionar a sua resposta
Eric Amaro será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 353
