Ir para o conteúdo principal
The HTC Desire 816 features a 5.5-inch display with a 1280x720 resolution, 13 mp rear facing camera and HTC BoomSound.
How to unlock the pattern while the screen is cracked?
My htc desire 816 is broken, the screen is cracked and i can't see anything properly. It has a pattern lock and I am unable to unlock it because of the cracked screen. So is there any way to unlock my phone.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
use any type of screen cast to cast you phone screen to your PC and then viola!! you can control it from your PC.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
No other way until you fix your screen .
Esta resposta foi útil?
Pontuação 1
not sure if I I did this correctly, but use a stylis to open your phone, that way you do not cut your finger, that is if you know your code.
Pontuação 0
Adicionar a sua resposta
Sanuar Chowdhury será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 16
Ao todo: 818
