Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone xr. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 6.
Sound not working even after speaker replacement
Have a 6 with no sound.
Have tried the following:
-Replaced speaker
-Replaced dock connector
-Restore to factory settings
Anyone else have similar problems?
Thanks
James
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
sound works through earphones
por
Adicionar um comentário
2 respostas
If there is no sound through earpiece, and headphones, then the audio IC may be faulty, but since you are only experiencing problems with speaker, I would try cleaning the speaker contacts with alcohol.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thats not a bad shout except I have replaced both the dock connector and the speaker so the contact between the two should be spotless. I have also removed the rubber and wire mesh from the housing directly below the speaker hoping that maybe it was just too clogged up......no luck
por
Where did you buy the dock connector from? Also, do you have microphone and earpiece functionality? like can you call someone?
por
Did you manage to fix this issue? I am having the exact same issue
Pontuação 0
1 comentário:
I’m having a similar problem with my daughter’s iPhone 6. It was dropped in a bathtub and then she continued to use it for a couple of hours before bringing it to me. Initially it was stuck in headphones mode. I disassembled and dried it out as best I could with IPA. Let it dry overnight (not long enough, I know). Reassembled and sent her to school with it. Initially the speaker was still working but it stopped later the next day. Replaced the battery a few days later and tried to clean the speaker contacts again. I have just replaced the speaker itself but there is still no sound. The earpiece speaker works, mic works, headphone jack works. Just no sounds at all from the loud speaker.
por
Adicionar a sua resposta
James será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 135
