Ir para o conteúdo principal
How Can I Remove Stripped Screws from the Edge of 6s Screen?
Hello,
I am replacing the screen on a previosuly water damaged 6s that I have thoroughly cleaned out, and I cannot get the screws off the back plate of the screen, apart from 2... 4 are rusted in. What can I do to get them out? Thanks...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Are they the holding the backing plate on the sides of the screen? only option is to use a screw extractor or drill them out then replace
Esta resposta foi útil?
Pontuação 0
4 comentários:
You can also possibly try a torx bit as well or a flathead, I managed to get a stripped logic board screw out by using the torx bit you would usually use on the bottom screws
por
Thanks, where can I fix screw extractors small enough for an iphone? heh
por
Hello? Id like to know where I can find them I honestly ant find anything...
por
Just drill them out with a drill bit as big as the head of the screw
por
Adicionar a sua resposta
ZsTech será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 121
