Ir para o conteúdo principal
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
20 Perguntas Visualizar todos
My music sounds distorted
Whenever i play music through my Samsung Galaxy S6 speakers, the music sounds kinda distorted. When i use headphones, the music sounds perfectly fine. I know there's nothing wrong with my phone speaker because everything else besides the music on my phone sounds fine. It hasn't always been like this. It just started sounded all wierd not too long ago. Why does it sound like that? Can i fix it?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
i have a goe as new (real new without slightly traces of use) sumsung galaxy s6 and when i tested the loudspeaker with music, it clearly show me distortion specialy with more bass on equaliser. also audio by telegram, whatsup,voice recorder. but super quality sound when i use headphone!! why is that?
por
It is a very common issue and almost faced by many, I have also wasted a lot of money in buying the handfree and after the usage of a month and two either one of its side went mute or the pin through which we pluck in has the issue. I don't know when the companies start creating durable products.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Maybe your Phone uses the AdaptSound Funktion or any of the other "Sound Optimisation" Funktions to optimize the Sound by using Headphones. With this Funktion the Sound could be not normal with the internal speaker or external Speakers.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you for this info
por
Adicionar a sua resposta
Lindy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 1,556
