Ir para o conteúdo principal
The Samsung Galaxy S6 Edge+ is the larger variant of the Galaxy S6 Edge smart phone.
How to replace the HR sensor glass?
I have scratched the heart rate sensor glass and it looks terrible. I need a replacement for it. Can it be done?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Simple answer is yes. All you need to do is replace the chassis.
Just be careful removing the battery cover as they can easily become damaged or cracked during removal so I would suggest removing the battery cover first and if you do crack it you can order a new one or if you get it off cleanly then order a battery cover gasket.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Artej será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 263
