Ir para o conteúdo principal
Released September 26, 2007 by Sling Media and can be identified with the part number SB260-100. The Slingbox is a small box that connects to a network where the user can DVR, cable box, or satellite TV receiver using a computer, phone or tablet connected to the same network.
What might be causing a rattling noise in the Slingbox SOLO?
It sounds like there is plastic moving around in the Slingbox SOLO when it is moved. It might be the casing, how do I check to see if the casing is broken?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The case might be broken or there might be something lose inside.
You can take the case off and see if any small pice falls out
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Taylor Espich será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 114
