Reset without apple id
I bought a iPad air model A1474 from our local flea market.... It has been reset but apparently I need the apple id which I do not have.... Can I still setup the iPad or have I been ripped off...
Esta é uma boa pergunta?
Bricked forever, yes you got ripped off.
Esta resposta foi útil?
There has to be some way to reset the thing, right? Flash this or replace that...some work-around that might be against a certain company's policy, but his purchase of their product DOA, should Trump any reason in keeping some unbricking trick or hack a secret...
Sure, replace the logic board.
Ipad Air Wifi only ? what was right months ago is not more actually.
For a reason I don't know (leak or other thing) Idevice Wifi only can have Find My device deactivated for few bucks (10 €) . With FMD deactivated you can reset the Idevice without any problem.
I don't know how it's possible , especially if you consider that in the same time GSM devices are still very difficult /expensive to reset if FMD is activated . I tried to Google that, but I don't find exactly what can explain that nowadays it's so easy to unlock a Wifi device whereas it's so complicated to do the same for a GSM one!
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 797
