Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
New iPhone started to charge really slow after two days usage
Hey, my brand new iphone 5s takes hours to charge, it takes almost 2 hours to charge to 20%. I got it 3 days ago and i have tried to charge it with computer, wall charger, charge bank. and if i use it while im charging it, the battery procents keep dropping. I thought it was maybe because one of my apps required more rush than the phone is getting so i restarted the whole iphone but nothing has changed. Is there anything to be done with it? Really sucks when i have just bought it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
5 respostas
Pergunta mais útil
thank you for all the answers, i did go to the apple store today, and they told me that the problem was probably my charger but this doesn't add up when i have tried 3 different chargers and they all work just fine charging my brothers iphone 5s.
Esta resposta foi útil?
Pontuação 1
claim a warranty as it should have at least a 1 year guarantee.
Pontuação 0
Have you tried to replace charging socket?
Pontuação 0
1 comentário:
yes i've tried to charge it with 3 different chargers which all works when my brothers uses them to chrage his iphone
por
I agree with Synced Repairs, but if you didn't want to take it back without trying some things then you can;
1. Make sure you use a 12w adapter to charge the phone, and a decent lightning cable
2. Do a software reset - Just press and hold both the Sleep/Wake and Home buttons simultaneously for at least 10 seconds, until you see the Apple logo. You can let go of both buttons after the Apple logo appears.
If that doesn't work, take it back to an apple store and they might just give you another phone (if it's the first time you've gone there).
Hope that helps :)
Pontuação 0
I would say your best bet is to try a different cable and plug to be sure it isn't due to either of those. Then bring it into the apple store for diagnostics. If they can not determine issue I would check back with where you purchased the phone and ask for an exchange. It may be a bad connection as that is not normal.
Pontuação 0
Adicionar a sua resposta
Kh Mnt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 102
