Ir para o conteúdo principal
A linha de laptops MacBook Pro da Apple foi concebida para usuários avançados e profissionais. Atualmente, a linha MacBook Pro inclui as variantes de 13, 14, 15, 16 e 17 polegadas, com revisões maiores definidas pelos designs Pré-monobloco (original), monobloco, tela Retina, Touch Bar e SOC (system-on-a-chip).
20012 Perguntas Visualizar todos
Pergunta encerrada
HDMI connection
Is there any way to add a HDMI outlet to my Mac Book pro? Currently I have to hook up an audio cable and a video cable when connecting to my TV. It would be nice to have just one connection and wouldn't that also give a higher quality picture?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
5 respostas
Solução escolhida
All you need is this
Esta resposta foi útil?
Pontuação 1
No. You would have to drill a hole in your case for the connection and then find room in your laptop for the hardware. The only thing that I can suggest is to use the mini display port and a converter to get the closest quality picture to HD.
Pontuação 0
The mini display port adapter is all well and good, but only if you have a unibody MacBook. If you have an original MBP, you can get a simple DVI to HDMI adapter. However, you won't be able to send audio out through that.
Pontuação 0
Here's a DVI to HDMI cable that should work:
http://cgi.ebay.com/NEW-DVI-HDMI-DIGITAL...
Pontuação 0
You can go to try [Audio Book Converter|this].
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,765
