Ir para o conteúdo principal
Why can't I hear anything on my right side speaker? (G500v Headset)
Hello, one day i was using my headset when suddenly the right speaker stopped working, there was no sound, this is my headset http://www.geniusnet.com/wSite/public/Da... .I've been trying to repair it but had no luck so far, i opened it up and it looks like every wire is well soldered, there are 4 of them, sending some images here:
After that i thought it was maybe the jack, so i bought another jack, soldered all the cable wires and it works, but still no sound out of the right speaker so i guess my jack wasnt the problem, can anyone suggest something else i should check? thank you!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@giulian23 I'd briefly connect that speaker to a different audio source by using two different wires. If the speaker works with different wires and a different audio source you know that it is okay. If not you will know that the speaker itself has failed. If it does work, check your wiring between the jack and the speaker (use a multimeter) for continuity.
Esta resposta foi útil?
Pontuação 3
2 comentários:
i checked the continuity on both my working speaker and the one that doesnt work, it looks like the wires from the top part are from the vibration system, the ones at the bottom half are the ones from the speaker, in the left one both showed continuity, in the right one, one of the wires that went to the speaker (the red one) didn't do the beep sound on my multimeter, so.. maybe i should change that little wire, but im afraid of dissasembling the headset to try and cut the bad part of the wire lol, any tips?
por
I'd try and run a temporary wire first and see if a new wire will get it to work. If it does than you'll have to think about disassembly (PITA)
por
Adicionar a sua resposta
Tano será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,997
