Ir para o conteúdo principal
Sensar or front camera is not working
After chnge the screen my phone was working good bt some time it turn off and it is restarting and apple logo come again again bt phone is not open.after removing the sensar plate it open and front camre is not working.if i restart this then same problem is accruing and i need to remove sansar plug to start my iphone?any solution? ??
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
This happened to my old iPhone 6. The sensor needs to be replaced, mine wouldn't boot up unless I unplugged it, cause it's causing a short circuit
Esta resposta foi útil?
Pontuação 0
1 comentário:
I changed 2time bt the main problem in jack.?sensor is okkk
por
Adicionar a sua resposta
Saini será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 47
