Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Advice on dead iPhone 5c
Recently bought an iPhone 5c that was listed as faulty. Phone powered on and worked fine just had a few minor issues such as the Bluetooth antenna and the front camera needed replacing. I made these repairs , but when I put it back together now I'm getting no powers , no charge and no iTunes either. I think I can rule out the battery as I tried a brand new battery I have in it and nothing. I noticed the indicator on the logic board was red not white which indicates water damage. But my device had been working fine prior to doing repairs. Is it possible for my device to have been working with water damage and now it's died because of it, or is it another problem ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I work at a phone repair company, most of the times a phone that is water damaged, when swapping components, it short circuits the phone. It shouldn't be the battery because you said it was turning on before.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Oh okay thanks for the reply , this may be a stupid question but can it still be repaired ?
por
It just depends on how much corrosion there is, but yes it can be fixed, most of the time you'd want to take it to your local phone repair shop cause they have machines just like we do at my work where we drop the mother board into a tank with cleaning alcohol and it takes away all the corrosion, but if you want to you can also try getting a brush with this bristles and some cleaning alcohol and brush down the mother board with it.
por
Adicionar a sua resposta
Kevin Pearce será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 99
