Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
lagging controller after optic drive replacement?
Replaced optic drive successfully. Now the controller lags terribly. I've read that it's something wrong with a Bluetooth component on the motherboard. It's just weird because I barely touched the MB when I replaced the Drive. But any help is appreciated. Thanks
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Anyone? ....
por
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like you have a problem with the WiFi antenna. First, check to make sure that the cable is plugged in under the power supply as it should be. If that's OK then you'll also want to check the large metal part that is on the disc drive. Check to make sure that the small wire is still soldered on to the large metal piece. I suspect that you may have forgotten to plug the cable back in under the power supply but it very well could be broken on that large metal piece in the front as well.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Austin Harris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 10
Ao todo: 101
