Ir para o conteúdo principal
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 Perguntas Visualizar todos
mic is not working?
Speakerphone works fine, Bluetooth works fine, headphones work fine. When i try to answer the phone normally all the other caller can hear is really loud static . Would someone be able to tell me the part i need? It's a 920p
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
This could be a few different things. This could be your earpiece speaker, this could be the I/O board (aka where the microphone is located), or it could be the audio codec on the board that might need reflowed. If you're just someone at home I would just take it to a shop unless you know what you're doing.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mike será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,400
