Ir para o conteúdo principal
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 Perguntas Visualizar todos
Home Button Connector Broke
I was replacing the digitizer on an iPad 4 and when I went to plug in the home button, the connector that is on the motherboard broke.
Is there any way to fix it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Replacing the home button connector is a fairly advanced level solder job. This is really not something you should try if you don't have board level repair experience. Best advice I can give you is to send it to a company called ipadrehab in New York. They do awesome work and are reasonably priced. Google em
Esta resposta foi útil?
Pontuação 1
I was hoping you would t say that
Pontuação 0
Adicionar a sua resposta
sunruh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 146
