My tablet saying : unfortunately google play services has stopped
Why is my tablet saying unfortunately google play services has stopped. the tablet is 4 month old.
Esta é uma boa pergunta?
Try some of these solutions
Solution 1 – Update Google Play Services to the latest version. You can download from here. You may be getting an error because you have a very outdated version or the one you have is having a conflict/bug with the current Android version in your phone.
Solution 2 – Clear the Google Play Services cache. The Google Play Services app in your phone acts like a framework for all the Google and Google Play apps installed in your phone. You can try cleaning up its cache and see if that would fix the issue. This worked with one of our team members! Read these quick and easy steps :
Go to Settings > Apps.
Scroll to All apps and then scroll down to “Google Play Services” app.
Open the app details and tap on the “Force stop” button.
Then, tap on the “Clear cache” button.
Solution 3 – Clear the Google Services Framework cache. The Google Services Framework system app on your Android device stores information and helps your phone sync with Google servers — and keeps your Google Play Services up and running. This could be one of the reasons why you are not able to connect to Google servers using the app and keep getting the error message. Read these quick and easy steps :
Scroll to All apps and then scroll down to “Google Services Framework” app.
Solution 4 – Check your Internet connection. May be your WiFi network is blocking any of the IP addresses that Google use. You can also try switching the WiFi on or off on your phone — same with mobile data.
Solution 5 – This goes without saying, but may be a simple reboot of your Android phone/tablet could fix the problem.
Solution 6 – I hate to say this, but in the end, you might just want to install a custom ROM that is stable with no bugs.
Hope this helps
Esta resposta foi útil?
I have an RCA Voyager 2 tablet and it's not letting me update Google play services please help I done a factory reset on and I cleared the cache and data on both ad it still won't let me update it
Mine is the same way. I did as suggested, the "force quit" button wasn't available and I uninstalled some other Google play services, now I can't get into play store to reinstall. Just white screen. Got nowhere.
download Google play services "apk" file from APKMirror or APKPure or UptoDown, etc and then install Google play services from this apk in the phone.
Is there anyone with an actual solution to this problem or is this just a bunch of things that "might" work. Can anyone comment who has actually had this problem and solved it?
Go to settings uninstall the app updates clear all data exit. Open app, it worked for me
Tablet software needs to be updated
how do I update software if google play store wont stay on?
I currently have the same issue.
I haven’t been able to do any of the suggested repairs. the “google play services keep stopping” continues to pop up every 2-3 seconds. If I start to go to the settings menu everything stops and I am returned to my home screen. Is there a way to start my Samsung tablet in some kind of “safe mode”? If I could some how get to the factory default setting page would setting everything back to factory defaults fix my problem? Thanks
Thanks for your help….but in the end I had to reset the tablet to factory default setting to fix my problem…thanks
I work for a cell phone store and I have had several customers come in with this issue. I found that if you uninstall the updates and reinstall them it fixes the trick.
-Go to settings
-click apps
-scroll down to google play services,
-on the top right click the 3 dots,
-click uninstall updates
You will need to go into google play store to reinstall the updates and once that is done your device should work back to normal.
Before I could uninstall updates on Google play services as above
I had to open settings then click security- other security settings-device administrators then uncheck find my device/phone
Then it allowed me to uninstall play sevices and restart successfully
@baseballcardsandmore Disabling "Find My Device/Phone" definitely helps in uninstalling the Google Play Services.
Thx, that did the trick.... go figure!
I have a rca Voyager tablet that is 4 years old and I keep getting notifications telling me to update Google play services (which I did at least 30 times). Can't afford to but a new tablet at this time. What do I need to update and how do I do it? I usually let my husband take care of things like this.
-Go to settings
-click apps
You will need to go into google play store to reinstall the updates and once that is done your device should work back to normal!
I had disabled the google play services app previously due to storage issues. When I go to uninstall updates, it tells me it is unsuccessful. Is there another trick to get the notifications to stop appearing?
Settings/security/ other security settings/device administrators/
Uncheck find my device
Uninstall updates on gpservices should then work
Restarted Samsung tablet..successfull so far
I have the same problem. I have tried everything but the factory reset. Why hasn't someone from google offered a fix. And why in the !&&* cant I uninstall and reinstall like other software?
@baseballcardsandmore how do you uninstall updates
Had a problem unchecking device. Went back to settings and came back in, this time found device unchecked. Restarted phone, would not give me a place to reinstall updates, but message has not reappeared! Hooray!
i solved this problem by download exact same version of google play services app which is in my phone from apk mirror here
Thank you very much. This worked for me.
Remove Google Play Cache
Cache is a temporary stored data that will help you to re-enter the previous page without having to reload.
However, sometimes this cache can be the problem, so you have to delete it . The method is quite easy.
Try reopening the Google Play application
I fixed this problem by replacing the SD card with more memory. My phone has significantly increased speed too. I have a J7.
If option is grayed out to delete catch or force stop, switch to guest user and run thru same protocol, that did the trick for me. This would be referencing a tablet not phone
What Do you men by
I did all reset to factory still getting google play has stopped and won’t connect to update any thing i now have two paper weights
Últimas 24 horas: 3
Últimos 7 dias: 27
Últimos 30 dias: 71
Ao todo: 461,798
34 comentários
But my settings are only not opening...than what should i do??? ....how to reset then???
por lavina naik
All about Google l can't get in with this message saying Google play services keep stopping what do l do?
por Samantha Hunt
I do not have the option to force stop
por Laura Roberts
No option to force stop. Google play services run all of the apps on the phone. Do I have to take it into a repair shop to fix the issue?
por Mary Gerlach
Settings > Apps > Google Play Store > Uninstall updates
por Yusuf Tangdilintin
Exibir mais 29 comentários
