Ir para o conteúdo principal
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
LG G2 screen fading
Hi,
after my phone fell by accident, the screen started fading and displaying vertical lines only on the left side of the screen.
BUT, when I apply pressure (press with my thumb) on the bottom left corner of the screen, everything goes back to normal. Except the vertical lines on the left side, they stay put. :)
When I lock and unlock my device, the faded screen is back and again I have to press it hard to get it to work "normal".
The screen is not cracked...
Any suggestion?
I'll upload some photos later so you can see the problem.
Thank you!
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Hi. I wanna see photo's
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi, this could be damage to the actual Lcd, or possibly damage to the flex cable of the LCD, it may even be damage to the connector where the LCD plugs in or it's slightly unplugged itself when you have dropped it, I would open it up and see if it is connected correctly, if that doesn't solve it, you may have to replace the screen. :-)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
jsintic será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 9
Ao todo: 823
