Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
Suggestions wanted for upgrading a 2009 13" MacBook Pro Unibody?
I have a mid-2009 Macbook Pro13" Unibody 2.56 GHz and would like suggestions as to how/possible upgrades in all respects: Logic Board, RAM and Hard Drive.
I also think it would be appropriate to mention that I am ashamed to have selected a new MacBook Pro 13" 2.7 GHz Intel Core i5 without the crucial upgrade-ability that the machines have had since their inception.
I don't see any major improvemet in fact I detest the force touch trackpad, the battery. and HD are glued in place and of course as we all knokw it barely breakes 20mph while running any application of signifigance.
I spoke to Kyle about using the water-jet cutting system to slice the darn thing in half so every day I use it I won't continually be dissapointed with the company in general for so crudely getting over on many of us new Macbook owners.
I have 2 - PowerBook 300 (Wall Street) units, a Mac SE 30 that I use as a soccer ball (it's square) and it still works beautifully!
Trapped and dissapointed!
Update (06/07/2016)
Hey Dan I think you are right. If I was to go with purchase of a gently used 13" or 15" or perhaps since I stay at home most days now,, how far back was the glue bottle utilized. Can I get a 15" from say 2013 or 14 that is still fully up-gradable? I could live very comfortably in Yosemite, shy away from the surfer / beach life at Mavericks cuz my surfboard broke up into seven pieces the last time i was brave enuf to paddle out....hozit I never realzied before that APPLE is on they decline and path to meet Dante.?
Thanks!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
The only thing that is glued is the battery in the retina series. The non-retina 2012 and older 13 or 15" MacBook Pro's have a screwed in battery.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
You have the better unit of the two in this series (Core 2 Duo). Sadly, you can't slide in a newer logic board as the mountings & port layout is very different. So that only leaves you the option to upgrade the RAM & storage.
I would max out the RAM here if you hadn't already to 8 GB, I would also recommend upgrading the original HD to a hybrid drive like the Seagate SSHD or if you can swing it you might think about going with a SSD. But be careful here! Your system only has a SATA II (3.0 Gb/s) SATA interface so the SSD you get needs to support SATA II. You should also make sure your systems firmware is up to date, follow this Apple T/N to check and update: About EFI and SMC firmware updates for Intel-based Mac computers make sure yours is at or newer that what is listed here.
As to the drives size you do want to leave between 1/4 to 1/3 of the drive space free, more so in a limited RAM system like yours. So look at how much stuff you have on your current drive and add to it to gage what you'll need. You may also want to peel away as much junk and old stuff you don't need off to lessen the needed drive. You'll find SSD's are the most expensive when you get to 1 TB vs a SSHD so keep that in mind.
The other option here is locate a used pre retina i5/i7 model system which does offer both RAM & storage upgrades over the newer retina models which only offer SSD upgrading.
I should also point out other MS Windows (cough!) system makers are also following Apples lead here with soldered RAM and limited storage options so that is the direction going forward.
Good Luck!
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thanks for the response Dan. IF and only if the logic board is not performing well and needs replacement is there any sense in using a mid-2010 model processor ? I've got the 8GB of RAM and a 1TB" ATA drive was on my mind.
I think the glue is not the correct way to go frankly for the HD and Battery.
How utterly disrespectful to the environment, let alone us geeks!
Thanks again!
por
Sadly, your CPU is soldered so it's not replaceable. Your only option would have been swapping out the logic board, but your systems mounts and port layout prevent using the newer i5/i7 logic boards. Thats why I was aiming you to a newer system (used) per retina.
Yes, the glue holding the battery was a big Apple mistake in the retina models! The newer MacBook uses 3M pull tabs which is a big improvement, I've jumped onto them when I replace a retina battery as its just smarter.
por
While Apple has moved to the front as more ecology minded company over many others, system longevity has not gotten better.
Some of this is not Apples failing as we the customer always want more powerful systems which does make it hard for any system designer to make the system upgradable. But, we can and should demand basic compatibility! The custom SSD is just a sad. I can see the reason why at the beginning they went that way, but now Apple needs to embrace the full M.2 standard, as well as offer extendable RAM options. Having the first bank soldered is OK, but allow the second bank as upgradable.
por
Upgrade to an SSD of capacity above 500gb and swap out the optical drive for additional storage with an optical expansion bay(opti bay). A 2009 MacBook is still very useable today. The SSD would increase the usable speed, in fact, the mechanical HDD is a relic compared to every other component in the computer. You will not regret it! i would also check if OWC has a memory upgrade beyond 8GB, I recall the 2009s could do 12gb but I could be wrong.
Pontuação 0
Adicionar a sua resposta
jranman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,234
