Ir para o conteúdo principal
Strange smell when running
Hi,
I recieved an ex-display Kenwood KMC560 today. And I tested the speeds with the whisk and water in the bowl. I noticed strange smell when I was changing the speeds. The smell is slightly metalic. I also noticed a bit of oil on the sides. The smell is a bit similar if you run an old motor. Is that normal? If it going to damage the product if I continue to use it?
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
This sounds like normal operation for this sort of accessory. Unless you smell something *burning* you likely don't have anything to worry about
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Alexander será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 580
