Ir para o conteúdo principal
The Acer Aspire M5 laptop series was released in 2013 and has since been discontinued.
Why will my laptop not turn on?
I have checked the power adapter using a multimeter (19.35VDC output). Verified that the AC port (connector to motherboard) has good continuity. The big issue is that neither of lights illuminate to indicate battery or AC power. I'm thinking the CMOS battery? Any thoughts? Any help would be great.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like a bad component on the motherboard. Be easier just to replace the motherboard if you can find one cheap enough.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you for the response!
por
Adicionar a sua resposta
Brothero será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 366
