Two Camera Not Working
hi
After Change LCD Two Camera and flash Not Working only see black screen
i need solution
Thank alot
Esta é uma boa pergunta?
hi
i need solution
Thank alot
Does your earspeaker work? If not, it's possible that you damaged the front camera flex, which can cause a failure of both cameras and flash.
Otherwise, try turning it off and on again (I know, basic but sometimes it works!)
Esta resposta foi útil?
i change my front camera and flex if my front camera not working , All camera stops working?
earspeaker and sensors is working... Camera Regulator is U3200?!
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 235
