Ir para o conteúdo principal
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
What is code F14?
What is code f14 on a Kenmore washing machine?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Washing Machine Displaying Fault Code F/14
EEPROM Error The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU. If there is an error reading th
The manufacturer has assigned this error or fault code to indicate that the central control unit circuit board (CCU) on-board program chip (EEPROM) is malfunctioning and so the rest of the circuit board is unable to get the data it needs to run the cycle properly. A power glitch can cause this error. Try unplugging the appliance for two minutes to see if that clears the error. If the code returns, you will probably have to replace the CCU.
Esta resposta foi útil?
Pontuação 3
You can also try selecting a different cycle. Eg, I got an F14 on delicate cycle. I paused and cleared machine then restarted on normal cycle, reselecting my water temp and load volume. Likely my CCU board is possibly going however I've had the Kenmore Elite H3 for over 10 years and during its lifetime, I've numerous codes pop up. I'm not entirely eager to run out and buy a replacement just yet. Fingers crossed…appliance rarely fails me! Good luck.
Pontuação 0
Adicionar a sua resposta
poppaof5 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 6,256
