Ir para o conteúdo principal
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
20 Perguntas Visualizar todos
Screen starts to come on, can see Dell
Screen starts to come on, can see Dell for about a 1/2 second, then nothing ?? Can hear it start up, but the screen is blank, so not sure of anything else.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@mrsfanasty attach an external monitor to your laptop and let us know if that makes a difference.
por
Adicionar um comentário
2 respostas
Try a power reset: Unplug Laptop, remove battery and ram/ Press the power button for 10 seconds then install ram, install battery and try to power it up. "Make sure while installing your ram, that it is properly seated".
Hope this works....
Esta resposta foi útil?
Pontuação 0
Its a battery issue unless you can still hear the fans of the laptop after dell logo. Power on the laptop without battery and let me know if it will work.
Pontuação 0
Adicionar a sua resposta
MJ será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 85
